View the thread, titled "Good Morning Thread - Come say good morning, tell us what you've got on today. :)" which is posted in The Electrical Exchange on Electricians Forums.
We got down on Saturday, and now have the lights fixed on the caravan…. (See other thread)
I should know by now, when choosing a site through the Caravan And Mortorhome Club, pay attention to where it says “non members welcome”
There is a contingent of, well… let’s see without being too condescending… large family units with too many people per caravan… too many vehicles per pitch… massive caravans of the Hobby and LMC variety. Broken toys, windbreaks, clothes dryers strewn about the grass and onto the roads…
19kg gas cylinders sitting outside the vans rather than the smaller 13 that fit inside….
And I know… I said it myself… it’s stereotyping…. But they all have a strong Irish accents.. even the toddlers.
To top all that off, first night we were here on Saturday… midnight to maybe 2am, it sounded like the filming of the next FnF movie in the town/ industrial estate nearby.
Last night was eventful.
The occupants of one of the caravans mentioned above had a full blown screwing match at about 7:30.pm
Shrieking banshees
It interrupted our monopoly game😂
Has anyone got their 7671 in front of them?
For installations on a caravan park, I’d there a reg that there must be a light at the hookup?
This site, every bollard has a light, but I’d say 75% or more are not on.
There is a notice in the shower block saying “some” have been turned off for reasons of light pollution and energy savings.
Don’t recall any reg about lighting up power points.
however it should be risk assessed and mitigated appropriately
Reg 712.3.2 - all night screwing matches are prohibited in mobile caravans regardless of earthing system.
Might not help in this particular case though.
Fault finding job this morning. Returning customer with an rfc downstairs tripping the mcb (no rcd)
Was at the house a couple years ago fixing the lights which had been ravaged by rodents a while ago and finally gave up.
Only 6 sockets, so whipped the fronts off and did a bit of testing. CU to first socket ok… first to second 0.06Mohm on L to E
2nd to 3rd clear
3rd to 4th also shorting to earth
4th, 5th and 6th ok…. But the cable leaving 6 is clear testing at socket, but short L to E tested at board…
Carpet rolled back in lounge and board up. Found the cables, but they’re run with a load of redundant cables that used to feed the kitchen… (kitchen is now elsewhere, and old kitchen is now bathroom) Cables look ok, no rodent damage here.
Next step is carpet up in hallway… trace from consumer unit to here they pass under the lounge wall…..
I have an uneasy feeling that there’s a radiator on the wall directly below the CU, and there is a possibility that the fixing screw for that has gone through a cable and has only just now broken down.
I’ll keep this job updated, but won’t be going back until after my hols.
Update as promised on this job.
Luckily there is no issue with the radiator. After lifting the hallway floorboards I can see where the cables go up the wall to the side of the rad.
Replaced the cable between 3rd and 4th sockets. Easy enough to tie a new one on and pull through.
Obvious damage on the cable whether it was a nail, or rodent… but it’s eventually broken down with a bit of a bang looking at the cable.
Also replaced the cable between 1st and 2nd. Much shorter length, only about 4m, no obvious damage but there’s a short between live and earth. Testing to neutral core is clear.
I’m going to dissect the cable and find out where the problem is.
Disconnected the return leg entirely which was also showing a dead short, but couldn’t pull the cable out to replace it… made the rfc into a radial and put it into a spare 20A.
Customer keen to upgrade CU to all RCBO, but not until any other faults are discovered, or the house gets a full rewire.
When your 16 your old daughter says “your van is cool” …. Is that a good thing or a bad thing???
Reply to the thread, titled "Good Morning Thread - Come say good morning, tell us what you've got on today. :)" which is posted in The Electrical Exchange on Electricians Forums.
