Good Morning Thread - Come say good morning, tell us what you've got on today. :)
The bead breaking is the important part. The tyres I run (Uniroyal Rainsports) have such pliable sidewalls that they are easily pushed over the rim by hand
I dislike fitting or removing runflats on my machine, but luckily it tops out at 18" diameter.
Most tyres will need balance weights adding though.
You'd be surprised how little balancing is required for a decent quality tyre on a straight wheel.
These days I have them fitted in the other half's work, so balancing is part of that service, but I rarely had to take home fitted wheels for balancing.
Sounds like we have similar machines. Disposed of because they won't take some of the ridiculous oversized modern rims and their equally ridiculous rubber band tyres.
16" rims and 55 profile tyres on mine. Pothole. What pothole?
My current car was factory fitted with 18" wheels, but sidewall of 245/45 still provides considerable cushioning.
No idea why people spend thousands to prematurely wear out suspension components.
I'll have you know I hold the same qualifications as the 'professionals' :D
a standard grade in woodwork?
My FIL, when he closed his garage and car showroom in the 90's rented the workshop out to kwikfit. (bear in mind, it was a family business and he had been trained as a mechanic in his youth)
He went in one day to get a tyre or brake pads or something, and was being told what else the car needed while it was up on a ramp....tyre, brake pipes, exhaust...
"bloody 16 year old, spotty eejit..... with "brake specialist" on his back!...... Specialist my arse... what does he know..."
etc etc
The manager had to come out and take over, ushering the young lad away when he realised the landlord was the customer....
You guys who think your wheels do not need balancing must be the caravan people who the rest of the world queue up behind. 🤣
There's a significant difference between thinking wheels don't need to be balanced and knowing the difference between a wheel that doesn't need to be balanced and one that does ;)
I tow a caravan and normally don't balance wheels but I'm rarely the one at the front of a queue.
There's a long downhill section when I'm nearly home, which has double white lines for miles. I keep it at 60 MPH, and, of course I do get quite a few cars build up behind, although I'm at the speed limit for them. This eventually opens up into a steep uphill section with an overtaking lane.
As I come into this, you see the whole lot behind you move into the RH lane as one, and it is at this point I drop down through the gears and floor the RH pedal.. If there's a reasonably powerful car at the front of the queue he may get past, but the usual scenario is for the lead car to get alongside me three quarters of the way up, then slowly begin to drop back as I'm still accelerating and he's reached terminal velocity uphill.
Totally immature and irresponsible, I know, but it's the way they all pull out to overtake en mass than provokes me, and I'm pi**ed off, because the holiday's nearly over.
Mike may have opened a can of worms as there are caravan towers on both sides of this debate.
I'm not among their number :D
There is no debate, if you drive slowly enough you will not notice your wheels need balancing, but you may notice the deterioration in vehicle ride quality as your shock absorbers prematurely wear out.
Back when I fitted my own wheels, driving at low speeds wasn't something I did much of.
Vibration from an out of balance wheel can manifest itself at any speed, although tends to be most common in the 50-70mph range. If that vibration appears at 50mph, you won't notice it at 65mph, but it will return again at 100mph. Likewise vibration at 60mph will return again at 120mph. The physics involved is outside my area of expertise, but its effects are very clear.
Dan,
littlespark,
