Discuss Good Old Delroy, he gets all the best Jobs :) in the UK Electrical Forum area at ElectriciansForums.net
Is the answer to the title 'competence' ?Bosh...
I see he's just left the customer to continually reset the tripping RCD 'until they can get someone to sort the dishwasher out'. Solid plan.Nah, couldn't pull the ruddy dishwashing machine out...
To be fair this is possibly the only option Del had left given he didn't want to attempt dragging the dishwasher out himelfI see he's just left the customer to continually reset the tripping RCD 'until they can get someone to sort the dishwasher out'. Solid plan.
It's not a fix though. He's just pitched up, done nowt except look in the FCU and then left. That'll be £100 please. It's not like it's a washing machine, it's a dishwasher. My wife can move ours.To be fair this is possibly the only option Del had left given he didn't want to attempt dragging the dishwasher out himelf
was it the customer or Dels apprentice?!! he seemed to be doing most of the work!I see he's just left the customer to continually reset the tripping RCD 'until they can get someone to sort the dishwasher out'. Solid plan.
sfs?was it the customer or Dels apprentice?!! he seemed to be doing most of the work!
someone should explain to Del how a SFS works, you dont have to unwire it to disconnect the load...
switched fused spur/FCUsfs?
AGREEEStopped watching him and CJR. I don’t think showing bad and or dangerous practice to the public enhances our trade at all.
Its like slowing down to look at a car accident, you know its not a good idea and wont achieve anything but you just cant help yourself!!!AGREEE
really? ok i thought they all were but i stand correctedSome aren't DP and won't isolate a N-E fault.
See, delroy us helping us all learn something!Managed to read the standard and stand corrected as switches on fused connection units must disconnect both poles.
Dustydazzler... this shameless self promotion has to stop ....!
It may have been added in at some point, and if there's no RCD protection in the consumer unit, is a way to provide RCD protection compliance for the new work. Let's hope not though cos del just removed it....Without digging out the regs books, can anyone comment on the RCD socket he removed and replaced with a regular socket? Isn't a socket there full stop against regs since it's directly over a sink?
I just don't understand why, even if there is RCD protection at the board, you'd remove that socket for no reason, given where it is. I thought all sockets had to be at least 300mm away from the edge of a sink but not 100% sure of the regs on thisIt may have been added in at some point, and if there's no RCD protection in the consumer unit, is a way to provide RCD protection compliance for the new work. Let's hope not though cos del just removed it....
I think the 300mm rule was one one of the older Regs that no longer applies anymore. I have seen pop up sockets fitted in brand new kitchens right next to a new sink way closer than 300mmI just don't understand why, even if there is RCD protection at the board, you'd remove that socket for no reason, given where it is. I thought all sockets had to be at least 300mm away from the edge of a sink but not 100% sure of the regs on this
If memory serves me correctly it stated in the electrician's guide to the building regs that sockets should be at least 300mm from he edge of the sink's basinI just don't understand why, even if there is RCD protection at the board, you'd remove that socket for no reason, given where it is. I thought all sockets had to be at least 300mm away from the edge of a sink but not 100% sure of the regs on this
Reply to Good Old Delroy, he gets all the best Jobs :) in the UK Electrical Forum area at ElectriciansForums.net
