He sold them allWhy don't you use the correct driver - a slotted PH?
Aren't they slotted pz?Why don't you use the correct driver - a slotted PH?
I still have boxes full of screwdriversHe sold them all
Same with a 5.5 slotted I reckon , you get sligthly more purchase on the terminal screw Vs a standard PZ or PH which can slip a bit when tightening downThe first time I used a +/- PZ I was surprised that I was able to put at least a quarter turn more on the terminal with the same effort, I was checking the tightness of them after installation with a standard PZ.
I then bought a Armeg torque screwdriver and that was a revelation how tight manufacturers expect the terminals to be torqued, in fact I sent it back to be re-calibrated as I thought surely not that tight, the Din Rail was bending with the pressure I was putting on it.The first time I used a +/- PZ I was surprised that I was able to put at least a quarter turn more on the terminal with the same effort, I was checking the tightness of them after installation with a standard PZ.
Agree, I have wrecked a couple PZ/S but never have snapped a 6.5 flat...YetPZ slotted is a vast improvement on PZ, but I tend to use 6.5mm flat head on anything over 3NM
Slotted screws can be a royal pain in the backside, but most problems result from using the wrong size of driver.Agree, I have wrecked a couple PZ/S but never have snapped a 6.5 flat...Yet
Was an old chisel ground down, I made it vde by using old pedal cycles handlebar gripsFormed from clippings of tin, I hope.
