Got asked to move a socket ..... | Page 2 | on ElectriciansForums
Discuss Got asked to move a socket ..... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Got a call from a customer saying they needed a socket moving as they are removing a wall ....... well actually its 2 sockets - the one to the left of the picture and the one you can see...
Both pieces of conduit have 2 x 2.5mm in them!
[ElectriciansForums.net] Got asked to move a socket .....
I didn't expect to find this in a 70's house ..... the wall to the right is the outside wall and behind the sockets is where the original kitchen was ......
Wonder where the conduit goes next?
I ran out of time yesterday to do any more investigation......
No idea that's why I posted follow back and see, they hopefully go in ceiling void.
Probably not Ant, personally in my experience it's going to be a case of look and ye shall find, or transferring from flush to surface wiring systems, the first thing would be to find out how the RFC is wired, the right way or the wrong way makes a world of difference in any alterations.
Tricky one that , what sort of test do you put on it once you’ve done the work , sure if you use containment for cpc you are supposed to use high current meter that injects 20/30a to check for good connections (Claire meter) if memory is correct , did a job for Ng Bailey for post office in early 90’s and we used containment as cpc
Clare B433R - Safety Testing - Seaward - http://www.seaward.co.uk/products/industrial-electrical-safety-testing-measurement-equipment/safety-testing/clare-b433r
Not sure if it was a post office spec on testing , but we defo had to use something similar to above
UPDATE:
Been back today ............ so I made the opening bigger into the wall:
And found that all the conduit was doing, was protecting the ring after it comes out of the cavity ....................
And one cable did link the 2 boxes together!
So all's good with the customer , who had agreed T&M for the work............. so I'll be sending an estimate later.
Thanks for the comments "team"
Reply to Got asked to move a socket ..... in the UK Electrical Forum area at ElectriciansForums.net
Sure, I'm on the Isle of Sheppey. also the cable they used I think was 2.5 twin and earth, although I could be wrong.
