got some of these to fit this week. | Page 2 | on ElectriciansForums
Discuss got some of these to fit this week. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
BG mini RCBO.
[ElectriciansForums.net] got some of these to fit this week.
look the dog's bollox. no functional E either.
I'd have to disagree, I always find them just as good as any [and often much more expensive] other brand. I've probably installed well over a hundred of these compact RCBOs already across a dozen or so new CUs, every terminal has been fine, they line up nice and straight and every test has turned out very well [Usually around 9-10 milliseconds on both x1 and x5 in my experience]. And as previously mentioned the BG busbar is the most substantial out there, far better than some of the flimsy rubbish that other 'quality' brands provide.
Fair point on the busbar, must be good for 500+ amps.
I've had no problems with BG boards, a few years ago the "wings" of the dolly switch on the MCB's where too long and wouldn't fall into the off position in the event of a fault.
Hager prices in Northern Ireland are nowhere near competitive for single face Consumer Units.
That screwfix price for the compact RCBO is shyte though.
I had problems with these and ouside emergency lighting, did all dead tests and was fine left for a few weeks then power was put on and when i turned them on it tripped instantly so went and had a look and tested the circuit at the last light and had a direct short to earth and it was due to these rcbo all 5 of the circuits had the same but when taken the rcbo out and tested it it was fine swapped with a normal rcbo and all was good. So i basically don't like them
Hi,so what was actually at fault,then?
Reply to got some of these to fit this week. in the UK Electrical Forum area at ElectriciansForums.net
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
ok cheers for the help lads
