Grade A LD2 fire alarm advise | Page 2 | on ElectriciansForums
Discuss Grade A LD2 fire alarm advise in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
No it is not a requirement, Grade A requires automatic detection in circulation / escape routes and rooms of high risk along with a control panel.
I'm gonna go with the Fike twinflex, multisesor heads and leave the call points. I've done my risk assessment and cant see as it warrants call points.
think if you pshed it, you'd be able to fit mains interlinked detectors. no control panel. that'd bloody overkill.
Going by the letter from council that's kind of what they say, then they throw a curv ball by writing grade A. If you go by 5839 part1 and 6 and look at the property, then it's grade A. Someone else has said install grade D to the bedrooms, lounge and kitchen and grade A to landings etc, to me that would be for self contained flats. Thinking of just subbing the alarm out and doing the board and emg lighting myself, lot less hassle.
How many floors is the property? Around my way HMO's require manual call points. I've never had a drama with customers saying they didn't want them...you need a panel, emergency lighting etc so they don't really look out of place imo.
Not uncommon for the separate dwellings to have Part 6 detection also. Is the kitchen communal because that is high risk and should form part of the Grade A system. Don't forget to allow for a zone plan this is a requirement of BS5839:1
Yeah communal kitchen is include that as part of the grade A on the panel system. Yeah I've got that on my to do. I maintained the fire alarm and sprinkler system at John Lewis distribution centre for 18 month, that was less hassle then this.
since the Grenfell tower fire most land lords have to step up to the plate .
regarding the property you are working is HMO and fire panel is in order .having read
that letter from the council to you client .you need to read carefully.
e.g. fire doors .
Reply to Grade A LD2 fire alarm advise in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Suggestions for best place to find suitable installers to quote?
