R
rob69
Hi All,
I have got a Grant oil boiler to install with an external timer unit.
The terminal block on the boiler has a "timer Live" and "timer neutral" connection.
Is it just a case of connecting the output from the timer to these and what size cable should i use eg 2 core flex?
Also , should i bond the copper oil inlet pipe or is this included in the boiler CPC and internal wiring ?
Thanks Rob
Thanks Rob
