Shoei
Interesting piece of kit, it looks as though they are manufactured for 120 or 240V, so the US version would need a transformer. The outputs seem to be switched from the input voltage so the loads (lighting, heat etc) also would need to run off 120V so the supply transformer would have to be sized to cope. 240V loads could be used using relays or with additional transformers but it could all get a bit clunky.
The US version is unlikely to be legal in Europe, it would need a CE label and I can't see one in the pictures. It's your call whether that matters to you but you should know about it to make an informed choice.
