Grenfell tower electrical "expert" | on ElectriciansForums
Discuss Grenfell tower electrical "expert" in the UK Electrical Forum area at ElectriciansForums.net
uk
For some reason, the grenfell tower inquiry has got an american electrical expert to comment on the electrical cause of the fire. And he doesn't seem to know a lot about BS7671 etc,
Firstly he thinks you can't trip an RCD after the MCB has tripped of a given circuit (presumably they have DP MCBs over there?), and secondly he thinks it's very improbable to trip an RCD and MCB simultaneously. Therefore he thinks most likely this happened in the first few minutes of the fire:
https://www.grenfelltowerinquiry.org.uk/file/2822/download?token=crUe0vAo
He also seems to think a more "violent" short circuit would be more likely to start a fire because the MCB wouldn't trip quick enough. And he uses the total clearance time (rather than pre-arc time) to decide whether there's discrimination between a B32 and a 13A fuse.
They could have got any british electrician in and they'd have done a better job than this guy!
Maybe the British experts guessed,there will be no thanks or glory,on this journey.
Sadly,as we have seen in the past,many,many times,it will be pingpong blame games,with no single entity,genuinely concerned with only the truth.
My own view,putting the obvious tragedy and sadness aside,is that it will be stretched out,for as long as possible,to enable the multitude of identical or similar situations,and therefore risks,to be part solved by natural replacement or regulation change refurb.
Anybody who thinks this complicated equation,will end with a definitive value for"x".....is going to be disappointed.
Sad really how this will drag on and on and no one will be to blame, I lived not to far from the Tower for about 10 years and used to drink in the Pig and Whistle or Garden Bar/Pub, one of the victims used to pop in from time to time and we'd have a chat, I recognised him from a photo in the papers and he was a really nice guy.
RIP
The cause of the fire is irrelevant, although it's required for completeness in the investigation.
A child with a match could have been the start of a fire in a single flat but the cause of the fire in the whole block is the cladding.
If it hadn't have been the Hotpoint fridge freezer in flat 16 it would have been something else in a different flat at a later date.
Totally agree. It was just waiting to happen.
How many people are now wondering how good their through crimps are that are buried in walls?
A tower block in Leeds recently had major flat fire. Flat was gutted fire didn't spread because it hadn't been covered in plastic.
Most likely becuase the surrounding area was full of yuppies who don't like looking at ugly coucil blocks and wanted a cheap way of cover them up.
With that many people in a small area, and most with little or no money, then there is bound to be questionable electricals involved.
But good design of the distribution systems can keep this under control mostly. But the cladding was unstopable. fate sealed.
I lived in the area, Grenfell is in the middle of a council estate.
Reply to Grenfell tower electrical "expert" in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
Norcal - thanks, belatedly. 'Tis the season when I don't get anything done, even though this project is near the top of the list. Per your...
