Grill element in the top of the oven has completely warped | Page 2 | on ElectriciansForums
Discuss Grill element in the top of the oven has completely warped in the UK Electrical Forum area at ElectriciansForums.net
Johnfyfe
Kilwinning
Hi, I have noticed the grill element is warped in the oven and hanging down. Is this dangerous and should I not use it
Thanks, I will attempt to get someone to fix it. Online is saying 2 week delivery time and I imagine it will be tough getting an electrician during lockdown, wife says I am not allowed to replace it.
hi they are very easy to fix make sure the cooker is isolated from the mains supply undo the two screws that hold the element to the top of the oven and allow the element to hang down slide the oven out of the housing and undo the screws that hold the backpanel in place which will expose the wiring you should be able to identify the wiring on the back of the element and take a picture of it the element will be help in by either two screws or some use 7mm or 8 mm nuts some use torx head screws slide the element out from the front reasembly is straight forward , if you let me know the model number i might have the element in stock and i can post one to you
Reply to Grill element in the top of the oven has completely warped in the UK Electrical Forum area at ElectriciansForums.net
Oh I see. I will check that one as well. Thank you!
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
