Ground Fault Detection Interrupter (GFDI) | on ElectriciansForums
Discuss Ground Fault Detection Interrupter (GFDI) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I
Ibis Designs
Some inverters are provided with GFDI and some are not. Is this a regulatory thing dependent upon the country of use intended for the product?
transformerless inverters need it, galvanically isolated inverters don't because they're protected by virtue of the DC being galvanically isolated from earth.
Hi Gavin
Do you have an example of such an inverter? I always thought that a GFDI must have a permanently grounded pole (Pos or neg) on the DC, where is Riso monitoring (like in SMA centrals) use a Bender relay, using PE as a reference point.
Meeb
galv isoltated inverters would be stuff like the old SMA sunnyboy SB series, but also NEDAP's power Router hybrid battery inverter is galv isolated.
Reply to Ground Fault Detection Interrupter (GFDI) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
It sounds like there is damage to the wiring underground. Do you know what kind of cable was used, in any underground wiring is used has to be UF...
