Ground floor flat rewire | Page 4 | on ElectriciansForums
Discuss Ground floor flat rewire in the Australia area at ElectriciansForums.net
Norwich
Evening all,
have been asked to quote for basic rewire in a small 2 bed ground floor flat. the ceilings are concrete as they would be. the flat is still wired in mineral cable with the copper outer sheath on a 3036 board. the customer was asking for a number of additional sockets etc, i suggested a rewire.
2 questions, would you guys recommend a rewire? and how do you about getting cables to lighting points, Surface & trunking?
any advice would be greatly appreciated!
with imperial you can have accurate measurements, say, 4 and 7 64ths. that converts to 105 and a bit millimeters .......rubbish
Now thats what I call accuracy
It usually looks to me that those mm lines are all one and same thing,gaps there are not :hand:
"where's my glasses" I must check this out
Reply to Ground floor flat rewire in the Australia area at ElectriciansForums.net
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
