Ground Mounted System | on ElectriciansForums
Discuss Ground Mounted System in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
synergy power
Hello,
What isolator switches can i use for outdoor use?
Also i'm running SWA AC cable up to around 30 meters, what thickness cable would you recommend? And also any recommended suppliers?
Thanks.
Hello,
Thanks.
10mm as the cost differential between that and 6mm isnt that great anyway... what do your calculates state ??
Just after help from you guys before i speak to my electrician tomorrow.
Sorry if the question is stupid, just want to make sure all of my work is done correctly.
Its not that there stupid questions, its hard to evaluate if your trade or end user, looking at your user name it would suggest your trade, but appears not.
Isolaters almost any of them as long as they are IP rated.
Cable CSA will depend, but i suspect 10mm.
Your electrician will be able to tell you what size cable to use. Tell him that it's a good idea to work on 1% volt drop.
Also, the AC isolators will need to be lockable in the off position only - a PV specific requirement.
Reply to Ground Mounted System in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
To start with the power companies don’t supply the equipment ground, that’s where the ground rods come into play. # 6 wire is required for the...
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
