grouping factor | on ElectriciansForums
Discuss grouping factor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
hi all
does any one know if there is a min length of cable which must be calculated for grouping
Ie
a drop of 500mm to a fuse board
a drop of 1000mm ect
and i read some were that these are for cables loaded 100% of the time so would these need calculating on a light bed room ring of lighting
500mm drop seems a bit excessive to me any comments
Grouping not normally used for domestic as it is very rare that all cables will be inuse at the same time, different set of circumstances in commercial situations.
Chris
Reply to grouping factor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
