Dzzi
Hi
My first post and i'd like to apologise in advance for the length of this post but i know how important it is to have all the information if you are going to help with a potential diagnosis.
A while back i fitted a 4 spot light gu10 bar type light and dimmer switch in my sons bedroom. While im not in anyway an electrician my Dad was and i am confident when dealing with the basics of replacing light fittings/switches.
Anyway all went fine, its been working for a year then on Sunday all the lights upstairs went out, the breaker (mcb??) had flipped and i pushed it back on with no issue, all lights back on except in my sons bedroom.
I know gu10's can be problematic so i thought, outside chance all 4 bulbs blew for some reason. My other Son has a similar light fitting, i took all the working bulbs out of his light and then tried the bulbs from the faulty light 1 at a time in this fitting 2 out of 4 failed to light.
I then took a known to be working bulb back to the light fitting that had the 4 none illuminated bulbs and tried it in each of the 4 holders one at a time, and nothing.
Other background info. I think my son has been leaving the dimmer on i.e. turning it right down and not switching it off by pressing it, or at least this is what my wife thinks he's doing.
The fitting is from screwfix (sorry if im not supposed to mention that) they no longer do it and im wondering if that is due to it going faulty after a while.
Ok so, I can understand 2 blown gu10's but why when i put a known bulb in each holder in turn does it now not work ?
I've not taken the fitting down as it's dark when i get home and i am concerned something outside my experience has happened here...so want to turn all the power off before i touch it.
Anyhow any advice or futher questions really welcomed as at the moment i can see myself forking out for a new light.
Dave
Dave
