GU10 Lamp replacement | on ElectriciansForums
Discuss GU10 Lamp replacement in the Electrical Tools and Products area at ElectriciansForums.net
T
toofasttoosoon
I have purchased a 2 gang 2 way electronic dimmer that will control acircuit of 6 & 9 downlighters.I currently have 35watt gu10s installed but want to replace these with LEDs when installing the new dimmer.This wont be cheap but i have just seen a warning on the box of the dimmer regarding the use of fused gu10 only .It is only recommended but before i outlay can someone advise me on this?: If i purchase 4watt LEDs will this damage the dimmer if there not fused............
Reply to GU10 Lamp replacement in the Electrical Tools and Products area at ElectriciansForums.net
Thank you. I guess i'll have to return this dimmer and find one without the Neutral. Thanks a lot for the help!
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
