Hello!
I've been trying to replace the dimmer to my living room. I installed a LED lamp and it's not compatible with the old one.
However, my new dimmer symbols doesn't match the old one. I've tried a bunch of combinations without success. I have changed dimmers in 3 other places without issue, but the main difference in this one is the 2 cables going into the same L(up) port.
Could someone help me with which cable should go where?
The old one has 1 cable for AC and 2 going into L(up). Cable colour doesn't seem to correlate to anything.
The new one has ports for Load Input (2x), Load output, Push Switch and Neutral input.
- TL;DR
- Trying to change dimmer, but i don't know which symbol matches the new one.
