GU10 LED downlighters | Page 2 | on ElectriciansForums
Discuss GU10 LED downlighters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As Bigsparks says, the difference in cost between non fire rate and fire rated down lights is minimal. In fact, I go further to say you'll be hard pushed to find a decent non fire rated DL. Even reasonable quality LED DL are manufactured to comply with Part B, but some also Part C & Part E.
Cheapest DL at Screwfix for example, non rated with lamp is about £4. Cheapest fire rated, with lamp is £7. But then your client might start moaning, when the cheap LED lamps start failing. There's decent DL now for sub £20.
Whilst the concrete floor is the actual fire barrier, and the choice of downlight will actually make no difference in the real world, I would still fit fire rated as my first choice, simply because I have gotten so used to fitting them, and the price difference isn't huge. In this case though, if the customer insisted on saving a few quid, then I would fit regular ones rather than not do the job.
i think the OP has been asked to replace the MR16 s with GU10 s in the existing non- fire rated fittings.
Reply to GU10 LED downlighters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
OVIA IBEX 5W EMERGENCY LED SELF-TEST NON-MAINTAINED DOWNLIGHT
