Query: I normally find the opposite.Yes, but little response. So, tires the Lighting Forum, which is proving a lot more helpful.
Discuss GU10's Failing in the Lighting Forum area at ElectriciansForums.net
Usage, Age and cheap components!What I am trying to understand is what could be causing this problem?
I think they changed their supplier since the new ones look different - but I've also had very few fail - and you can get 50 for £47 non-dimmable. I've had more problem with LED fittings failing tbh.I fitted around 50 LAP Gu10 led lamps in my house replacing all the old hologram lamps which most were blown. All on dimmers except the bathroom . In 5 years I have replaced 1lamp.
i just wish I brought more lamps as they were in clearance at my local screwfix at 99p each.
That’s a good price even for non-dim.I think they changed their supplier since the new ones look different - but I've also had very few fail - and you can get 50 for £47 non-dimmable. I've had more problem with LED fittings failing tbh.
Is it a higher than average voltage? Or could it be variable? Cheaper drivers may not like 240+ volts, even if it is within spec.5W LedHut 4000k. GU10, so no driver. I think they are Non Dimmable but may be dimmable. 28 Lamps on two circuits each with 10A rocker switches on a multi grid. High ceiling (4M) plasterboard, office above. 230v
Not sure how hot it gets in ceiling void. I'd have to put a thermometer in to find out.
I picked up a load of 4 x G9 capsule lamps at 99p the last time they had a clearout too - should last me years. Surprising what you can pick up if you are the first to spot them at your local branch...That’s a good price even for non-dim.
i remember the first lap led lamps were about 4 quid a piece , so when I saw them on clearance at 99p each i literally cleared the shelf.
they have come a lot in price in recent years...
I am planning to replace the 8 failed lamps with Aurora ones and see what happens to these. If others fail it will point to faulty lamps, if the Aurora lamps fail it could be a problem with the supply. I'll also place a thermometer in the ceiling void to record the max. and min. temperatures.I think on a job like the OP , I would buy a load of new branded lamps and replace the whole lot In one go.
make a note of the installation date and if they start to fail you will know how long they have lasted.
anything less than a year I would investigate further....
Not that I am aware of. Surely, if an IR was carried out you would do this from line and neutral to cpc and just at 250vDC.Has an EICR been carried out recently and 500v insulation test been carried out with lamps in circuit?
I cant see it being a 'faulty' lamps after 4 years or more, especially with the usage they will have been subjected to in a hairdressers.
The rated hours are just a guide, not a guarantee that they will last that long.
In an ideal world but errors are sometimes made!Not that I am aware of. Surely, if an IR was carried out you would do this from line and neutral to cpc and just at 250vDC.
[automerge]1601027176[/automerge]
Reply to GU10's Failing in the Lighting Forum area at ElectriciansForums.net
