N
Nathz101
Hi people, as I've said before I'm a new apprentice working for a local electrical contractor .. We're currently workin on a new build wiring up doin first fix so I thought I'd buy myself the new onsite guide and guidance notes 3 which both arrived today so I could have some sort of knowledge for when we start testing and thereafter ... I would like to know how people went about revising from the gn3 as in did you do it section by section and only moved onto the next section after knowing the previous ... And any tips /advice you have
thanks
And of course if you are slightly bunged up you read more, if your eyes aren't full of tears from straining to much.
Put it in the toilet, when you go for a dump, read it. it works!.
I find that if you sit down and try to read a book like that cover to cover, its hard going, if you read a bit at a time say while on the throne, it sinks in
cheers for that lads not too sure about leaving it in the toilet lol but ill dedicate maybe a hour or two a day to reading a bit and taking notes
The boys aren't joking. We've 3 throne rooms in hightower mansion, and there's probably a dozen books split between them. Which toilet I use depends on which subject I could do with reading up on.
Guidance notes 3
Thread Tags
Nathz101,
ruston,
