Hager 100A main switch BS number? | on ElectriciansForums
Discuss Hager 100A main switch BS number? in the UK Electrical Forum area at ElectriciansForums.net
What is the BS number for a consumer unit double pole main switch, is it still classed a BS60898 ??
Cheers Ray Galea, just found it BS EN 60947-3: 2009 286 (BGB) Switches, disconnectors , switch disconnectors and fuse combination units. Old form never asked the BS number just the size (A) .
Reply to Hager 100A main switch BS number? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
