Hager 100A main switch BS number? | Page 2 | on ElectriciansForums
Discuss Hager 100A main switch BS number? in the UK Electrical Forum area at ElectriciansForums.net
What is the BS number for a consumer unit double pole main switch, is it still classed a BS60898 ??
might be on the side of the switch where you can't see it without dismantling. any road, if it's < 20 odd years old, it's a 60947-3. end of.
Reply to Hager 100A main switch BS number? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
