Deleted member 9648
Had to replace an MCB on an existing Hager board (dual RCD) as part of yesterday afternoons job. Having to drop the entire busbar just to change one MCB, and then fiddling around in a tight space to get it back, then the paranoia over whether I've missed a clamp. Mirror, torch...still cant really tell because of the shelf just below the CU.
Any board designed to make it highly likely that even a competent person cant be sure the devices are properly installed once the board is in- situ should be outlawed.
