Hager Light in consumer unit | on ElectriciansForums
Discuss Hager Light in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Northampton
I fitted a hager consumer unit about 2 years ago for a firm i used to work for and they gave me a module that was a rechargeable light that comes on with a powercut and that can also be removed and used as a torch. i have been trying to source one but cannot find one anywhere? any clues?
when ever I do a consumer unit change in an elderly persons house I always put in an emergency light normally throw it in with the cost , one I did was an 86 year old lady her consumer unit was in her kitchen next to her hall so I put it in her hall she was made up when she had a power cut , got them all round my house we get a lot of powercut round here normally change over time for the sheep !!I must admit people think jesus is visiting when there is a power cut only light for miles around and the number of time we get phone calls asking if the powers off
I have a maintained EML fitting in my cupboard that houses the CU.
I use it all the time as a normal light as this cupboard is my man cave and have the added benefit that it works when the power cuts
Reply to Hager Light in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
