Hager Light in consumer unit | Page 2 | on ElectriciansForums
Discuss Hager Light in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Northampton
I fitted a hager consumer unit about 2 years ago for a firm i used to work for and they gave me a module that was a rechargeable light that comes on with a powercut and that can also be removed and used as a torch. i have been trying to source one but cannot find one anywhere? any clues?
What does it cost ÂŁ14 for a maintained emergency light great if the consumer unit is in a cupboard there's nearly enough light from the indicator alone to see what you are doing be it green
Reply to Hager Light in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
