Hager MCCBs Advice needed | on ElectriciansForums
Discuss Hager MCCBs Advice needed in the UK Electrical Forum area at ElectriciansForums.net
T
thestig246
Hi im currently been carrying out at periodic on a caravan park. the board is a hager with these massive mccbs. There are 16mm cables which feed onto caravan outlets and the mccbs are all rated at 125A's... I dont see why this has been done and dont think its acceptable, surely the biggest protective devices for a 16mm is 63a tops??
I wondered if anyone else has had dealings with these boards and can you still get the breakers for these boards so i can down rate it abit!
il try and get a picture up once i famble it out!
many thanks!
Firstly what ref of Hager Board and MCCB is it? What the installation method for the cables, how far is it? Are you sure that the MCCB aren't adjustable and have actually been down rated.
sorry for the vague details! its a 16mm 2core SWA Burried Supplying three caravans with 16a sockets. where theres a 30ma 16amp RCBO. unfortunately these ones are no adjustable. If i could get a picture up it would tell 1000 words haha.
I didn't expect the final RCBOs to be adjustable, I would have been surprised if they were :)
[ElectriciansForums.net] Hager MCCBs Advice needed
[/URL][/IMG]
[IMGhh][ElectriciansForums.net] Hager MCCBs Advice needed[/IMG]
hope this helps basically you have a 16mm 2 core armored wired into a 125a breakers! surely thats too much for a 16mm? i just wondered if it had been done for a particar reason or was it all that was available..
A quick Google it seems they are rated 15kA Ipf, which may be needed depending what the Ipf is at the intake of that board, how long is the run to the RCBOs/caravan pitch ?
the 1st pic is on another db which is fed off this board as for tails theres alsorts of tricks like that going on, ive had a nightmare today, finding 0.50Mohm on my IR's as in places they have put undground joints in and just kept tapping off a cable, so you only have one cable comming to the caravan point and no way of splitting it ect. It seems a strange one as they have a 100a t/P on a 120mm cable and a 125a breaker on a 16mm cable!
the run would be aprox 50metres to the furthest pitch :)
it is mate, its on mum and dads holiday park, and ive had to tell them today that most of it needs rewiring as im getting really poor IRs bellow (1meg) there must be about 30 underground joints and they are inevitably failing!
Interestingly the previous person who carried out but on there report (no underground surveying on cables carried out, & 10% of insulation resistance carried out)
It varies really on that particualar board they are only feeding 3 caravans per 125a breaker.
whereas on the older part on the site theres about 10-15 running off some of the old 2c aluminium cables, (all with joints) :/
Reply to Hager MCCBs Advice needed in the UK Electrical Forum area at ElectriciansForums.net
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
M
Advice needed for fitting shower door frame? Hi, We're currently adding an en-suite to a downstairs bedroom, everything is going well so far...
Monster
M
