Hager part KRN190 neutral connecting block | on ElectriciansForums
Discuss Hager part KRN190 neutral connecting block in the Electrical Engineering Chat area at ElectriciansForums.net
1Justin
Surrey
Who's familiar with Hager KRN190? It's called a "neutral connecting block" by Hager with no further info. This seems a maybe misnomer, but I have never seen one in the flesh.. I'm assuming it would have a lower terminal spaced to fit a standard Hager busbar prong if it were fitted like an MCB?
(In case any worry why I'm considering this, it seems a convenient way to get an existing CU tail safely connected out of a common supply isolator, which contains protection mcb for a garage supply submain alongside. - The existing CU tails needing no protection. Lack of space, hence am trying to do this with a 2 unit CU and no henleys.)
When I've fitted stacked Hager SP boards, they use one of these to bring the L to the top row busbar (for an all-RCBO installation).
Thanks SJD. That implies it fits to the busbar. Makes sense, but why it's called a "neutral link" was what threw me. (And for Ferg, well it ought to, but that was where I found it, and it didn't in that respect :)
As I said earlier it would be used as the incoming neutral terminal when fitting a 3 pole main switch in a TPN board.
Reply to Hager part KRN190 neutral connecting block in the Electrical Engineering Chat area at ElectriciansForums.net
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
