Hager RCBO to fit old board | Page 2 | on ElectriciansForums
Discuss Hager RCBO to fit old board in the UK Electrical Forum area at ElectriciansForums.net
Lincoln
Hi all
Would anyone know if a new Hager RCBO would fit into one of these old Hager boards?
I have to do a small amount of work and there is no RCD protection.
Malc
[ElectriciansForums.net] Hager RCBO to fit old board
We test a lot of schools and a large percentage use the MK sockets with the outboard switches. I would not mind a pound for the amount I have replaced where they are cracked across the front plate or the switches are faulty.
Got to conclude they're not so good as they used to be the MK pull cord in our bathroom lasted 45 years. I think that they used to manufacturer all in the UK not know though. I suppose its due to pressures of competition.
yeah ,just the other day replaced a mk 45 amp pull cord switch about 2 year old. all Chinese c**p now.
Reply to Hager RCBO to fit old board in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
I wonder if a double row Fusebox would fit in there…
