Hager Split CU, RCD now nuisance tripping. | Page 2 | on ElectriciansForums
Discuss Hager Split CU, RCD now nuisance tripping. in the UK Electrical Forum area at ElectriciansForums.net
M
Matt Smith
Hi all,
I fitted a new Hager CU about a year and a half ago for a neighbour in our area, and all was fine, although the people who live in the flat are very odd and not very bright to be generous ! anyways the board has the split 30mA Rcd's one each side and type B MCB's after them.
I have split ring final cct's across the two halves of the board and lights etc..
Problem I have now is that the Rcd covering 3 x MCB's on one side of board keeps dropping out, it covers water heater cylinder, kitchen ring main and another ring main only, all with their own mcb's too. I reset the rcd upon visiting and it tripped again so I tried each mcb load one by one and water heater fine etc.. and offending item was the kitchen ring tripping the rcd after approx 4-5 seconds !
I checked with person that it's been fine for best part of 18 months and they said yes no problems before now, I am therefore unsure if it's tripping on earth leakage or possibly overloading without taking out the mcb ?
They informed me only thing changed was a washing machine a few months back which I am sure they leak to earth and as would the fridge/freezer which is also on kitchen ring.
On inspection in kitchen I found one old single socket feeding a 4 way extension and onto another 4 way lead into which we have a washing machine, fridge/freezer, toaster, steamer for food cooking, and a kettle too and now and then the microwave ! all from one single socket !!
I tried to explain that this is way too much load for a single socket but she told me it's been no problem for 36 years so far..
she asked me to take away the rcd and put in a main switch on the problem side of the split CU which I explained would be illegal and not to 17th regs then.
Today she came back saying she had bought a new 4 way and yet it still trips out !! I don't think they are getting this...
I can't run new rings to split it up as flat is totally concrete and bursting with grot and junk high up every wall and to be fair I do not want to work any further in the premises as it's a health hazard.
Anybody shed any light on how I can counter the nuisance tripping or advice if you think is washer, fridge compressor etc... all just accumulating earth curent or does 4-5 sec delay to trip sound like overloading ? Thanks all, M.
Hmmm I know a lot of guys who were NICEIC or held 2391 were going all over testing for others and charging cash private jobs £650 a board single phase and more for 415V Polestar boards etc..
I have only my 2360 part 2 and "C" Course passed but not the testing ticket unfortunately. But you guys are right, maybe I should get some test kit and do my own in future as I can carry out the schedule just not probably sign off the results.
Did your mate do any tests for you before you changed the board? Always very good practice!
I know most of us on here would change the board and fully test, certify and notify for much less than that!
Cripes - you'll get overrun with sparkies with rates like that!!
Yep I do know that RCBO is overload also but I have had peoples laptop chargers cause enough leakage to trip an rcbo or rcd before so am thinking that the combination of a fridge compressor, and washing machine too will be plenty enough leakage to earth to trip out a 30mA rcd..
Thanks so much for making me seem a total cock though guys.. Nice. I mis-typed that's all.
I may seem to have paid too much, but I was willing to cough up so that I knew that the home was tested and safe that's all.
But it was OK before! There will be a faulty appliance somewhere.
I'm not understanding this at all!!!! How can any electrician work without any test equipment to his name?? Is the OP self employed or is he engaged in employed electrical work and only does a bit of domestic work on the side?? Probably the latter!!
He obviously isn't registered with a scheme provider, if he doesn't have the required test equipment, so i don't know what's going on, that's the only reason i can think of, to pay someone else to test for you!! lol!! Now if this CU cost £300 to test, how much did the whole CU change cost this customer???? The mind boggles!!...lol!!
Ok so no testing done before cu change? I fell foul of that once, and only once!!!
What's the insulation resistance test results now, i mean after the boards been changed? Not all but just the ones from the side that the rcd is tripping will do.
my money's on the water heater, what about everyone else?
I'm putting on my tin hat here........I do grow weary of people, albeit perhaps not ‘Competent’, posting on this forum and being ridiculed for their lack of knowledge, skill or expertise. I think Matt realises he needs to carry out tests to establish the root of the problem. I sense from his tone though, he wished hadn’t posted in the first place. I suspect he thought he could use this forum to broaden his knowledge by getting advice from experts & experienced electricians. Perhaps this stance will encourage the budding spark to go away and get properly trained.
To think that is the case is pure utopia, and I fear some might not dare post & just go andtakeaway the rcd and put in a main switch’?
Reply to Hager Split CU, RCD now nuisance tripping. in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
