Halle-flippin-luyah...the AVO835 is on route... | Page 2 | on ElectriciansForums
Discuss Halle-flippin-luyah...the AVO835 is on route... in the Electrical Tools and Products area at ElectriciansForums.net
Well,all things equal,i should have yet another toy to play with,in the morning;)
A 28ii is on route:cool: not bought from the yellow stable,for a while,i hope my existing grey,black,red and green devices,make it welcome ;)
The 28ii? ....only had it for 12 hours,but it seems the business:D
After my previous excitement was muted,i will continue playing with this,until all it's functions are demonstrated...which means a visit to some VSD set-ups,and similar.
It does feel indestructible,and the stated spec,allows for a washing machine clean,at 40 degrees;)
Twist guard leads are nice,lantern tips removable,and clips not bad,although i will add a larger set.
There are a lot of additional features,some are enabled with a "power up" method,and these would have been handy,listed on the Quick Reference Guide,but i am already revising,for my weekend exam:cool:
[ElectriciansForums.net] Halle-flippin-luyah...the AVO835 is on route...
Well,i can report that the new 28ii is a very nice bit of kit.
I spent a week or so,getting to know all it's functions,and finding ways of using them,in real-world type of situations,and have not been disappointed.
I have used it on a couple of tasks,where it's variety of ranges,including temperature,enabled the use of one device,which was handy. Twistguard leads are very nice,and i bought another set,for use on another non-Fluke device :)
I have the twist guard leads for my fluke 119. However they are a very tight fit in the holders at the back of the meter. (My 119 is probably 8 years old now).
Have they changed the design on the newer models to make them fit better when you wrap the leads up around the meter?
Hi,i take it yours has the rubber case with clip-ins,at the rear?
Mine does not have these,as it is a lump of a thing,to start with,and that facility adds further depth :)
I would very rarely do the wrapping thing,as in the past,a drop,scuff or impact,in that state,always means the leads cop for it.
I have not owned a large range of Fluke equipment,but used it enough. They have some excellent extras,but as always,some could be improved or be cheaper.
Their magnetic hanger looked useful,but on inspection,seemed expensive. I chose to make my own,using some webbing,and an incredibly powerful little rubber covered magnet,i obtained,from the cable containment gear,on off-shore wind turbine towers;)
I can almost dangle meself,off it...so probably overkill :cool:
I wrap them just for that very purpose. I'd rather replace a set of 10 - 30 quid leads than a meter.
However my 119 has been thoroughly abused, dropped, taken in the rain, out in quarries, dusty, hot, freezing environments.
Doesn't look as pretty anymore, still works and passes calibration every quarter still. I should maybe treat myself to a shiny new one for the workshop. Keep getting tempted.
Hey,Rob,mine does have recesses for probes,in the back...didn't even see them!
They are tight,i suppose due to allowance for the rubber softening. Still lovin'it :)
Right...wet Monday,here,so bit of an update,regarding the two kids (meters)
Firstly,the one that went back to the maternity clinic...the AVO835. I have to admit,to being very disappointed with this yoke...having waited for it's eventual release,some 24 months,it was evident why there was probably such a delay.
I believe the design and build quality,to be lower than required,and this has maybe contributed to a lack of reliability,which would explain the repeated failure to stick to a stated release date.
Basically,on certain range settings,the meter would glitch out of it's setting,at random. It could be switched back in and out,by a gentle press on the front panel,or squeezing. I made a video of this occurring,and it was easily repeatable.
The meter came with the usual test/calibration certs,so,it was either not tried,or failed on it's journey to me,in a very comfy box,so not confidence inspiring...
The other option,would be,that it just wasn't made correctly...either just that one...or all of them,again,not good.
There was no dispute with my return of the device,or reason,so not the end of the world,just a black mark in a copy-book.
So,the second baby, Fluke 28ii,was delivered,and has been potty trained and fed,in order to give an opinion.
Fantastic bit of kit :) used it as much as possible,to test all it's functions...even used the temp probe,to check core temp of a steak,while away camping ;) love it,and definitely glad i chose it,over other devices.
Just a final note...my 11 year old noted it was "a bit of a lump..." so,i had to explain that the first mobile phone,his dad owned,weighed 4 times as much,and was twice the size o_O ...i'm still not 100% sure,he believes me!
well show him this.it was my first mobile phone. was just a bit smaller than a house brick.
The only negative feedback I have read regarding the Fluke range of multi meters is regarding the LCD screen failing or going dim. Only on certain models and only ones produced outside of the USA.
Some are being produced in China,Taiwan, Japan, somewhere, I can't remember. They use a different brand of LCD screen to put in the meters as opposed to the ones made in the USA.
Would be interesting to know if this Fluke 28ii has anything on it to work out where it was manufactured.
That's mobile.....mine was only transportable...and it's monthly bill was 5 times my present one,which is probably another five-fold less,due to inflation?
[automerge]1568039351[/automerge]
I will try to find out,but stamped "made in" usually means some/part/none?
@PEG interesting comments re build quality with Megger. My AVO has been fine and dandy but we recently bought another 1741 MFT and the top and bottom hadn’t been fixed to each other. On picking it up it came out of it’s bottom section revealing the guts of the machine. Like your experience Megger took it back via the wholesalers no questions asked but it makes me wonder if there are quality control issues with some things; or did we both just get Friday afternoon builds! ?
My first mobile phone...actually a car phone...got a second wiring loom for it and used it on my boat...
until a few years later folks were using smoke-packet sized things. That was when i realised analog was dead!
Hi,had a check,and it states "US" and on the back case,"Assembled in the US of US and Foreign Components"
To be honest,it's never bothered me where,just how. Design-Materials-QC ...always in that order...they just have to stack up,and remain reliable,in the real world.
Sadly,there are less and less things,which meet that criteria ;)
Reply to Halle-flippin-luyah...the AVO835 is on route... in the Electrical Tools and Products area at ElectriciansForums.net
