Halogen lights not working? | Page 2 | on ElectriciansForums
Discuss Halogen lights not working? in the Australia area at ElectriciansForums.net
R
Rio
Hi I have 12 halogen lights fitted into my ceiling with this light switch fitted onto the wall[h=1]GU6422EWPC Ultimate screwless flat plate 2 gang 2 way 300W electronic dimmer polished chrome white insert. [/h]So 1 half of the switch controls 6 lights and the other half of the switch controls the other switch. However only 1 half works (which means 6 lights come on) but when pressing the button for the other half to come on the bulbs flick on straight back off again.
They did work a few days ago but someone has been messing with them and as I don't have any instructions for the switch I am unsure what the problem is. I tried changing 1 of the bulbs but that didn't work. For some reason the 6 lights don't want to stay on like the rest of them.
Please help many thanks
all sounds right but if u change to 7w leds you'll need to change dimmer aswell to a trailing edge or leading edge can't remember which way round. as normal dimmers start at 60 va rather than 0
Reply to Halogen lights not working? in the Australia area at ElectriciansForums.net
Loose neutral somewhere… possibly at panel or at the last light before it goes to panel. You say you’re getting power through the switch and up...
I have a bar light that the bulbs burned out. It had E11 bulbs with .1watt each with a 2 batties with double AA in it to run. I am looking at...
