Handy notes to keep in phone | Page 2 | on ElectriciansForums
Discuss Handy notes to keep in phone in the UK Electrical Forum area at ElectriciansForums.net
Wales
I have all the new brown books and other electrical books but I was thinking it might be a good idea to keep a note in my phone of things I'm probably gonna want to know/check frequently. I'm still an apprentice. Should be qualified this year... And I think this might be a good way to hammer down some important things. I also only really do domestic stuff so far.
I have so far written down the ccc of cables that we use a lot (with relevant methods) and the voltage drop equation with the pages. Also zones for drilling joists. Max ze types. Any recommendations for something handy I should note? Thanks in advance.
No requirement for the x5 test now. What was the theory behind the x5 test anyway?
I am not sure, but possibly the old electro-mechanical sorts would take longer at low currents (the 300ms limit) but ought to be down to a short time at higher currents (where you are more likely to die), at least if not a "delay" type where 300ms is also a pass even then. So a test a 5*In would prove it worked fast / non-delay.
These days I think RCD will still trip without neutral (i.e. unpowered internal electronics) but don't know if that really would make it longer than the 10-40ms normally seen even at In testing.
If I have spare time and MTF kicking around I might try test that out,
Reply to Handy notes to keep in phone in the UK Electrical Forum area at ElectriciansForums.net
As it was explained to me, you can write anything in the book so long as it already exists in the book somewhere in original print. Tabs, etc are...
That is true it is not really a practical class it is expected you have some knowledge of practical testing before the class. I do a lot of...
