Handy tools | Page 3 | on ElectriciansForums
Discuss Handy tools in the Electrical Tools and Products area at ElectriciansForums.net
Good quality torch
Nah, it will only get lost anyway!
I've got a stack of 99p LED torches! They do the job as well as any of the quality alternatives but it doesn't matter when I'm an incompetent --- and leave them under floorboards or drop them in the bog...
One of my best head torches is currently entombed in a floor void.
Maybe one day a few hundred years in the future, some will pull it out of a pile of rubble and be pleased at their find..!!
Agree with the Bosch multitool. Invaluable for cutting tongues on floorboards, small sections out of plasterboard, plus numerous other uses. Go to sharkblades though for replacements, much cheaper than originals.
The two right angled screwdrivers, so simple yet so effective!
You know when the semi skilled put pipes right in front of conduit boxes, or a programmer 2" above the "wiring center".
I guy I worked with once had a bicycle inner tube cut into a 15mm long section then slit down the middle and tuned into a flat piece of rubber.
Sort of like a rectangular piece of rubber.
He kept four cable ties with it and said he always kept it handy just in case he cut through a water pipe with his circular saw whilst taking floor boards up.
The idea was to wrap the piece of rubber around the damaged pipe then secure with the cable ties to stop the leak.
He said it would save him for just long enough before a plumber arrived.
It doesn't quite fit into the category of handy tool but I think it is close enough.
I never did see it in action.
see what screwdrivers you use most often and what you really need and keep a spare in your bag, for example i keep a couple spare 2.5mm drivers and a spare pair of snips.
terminals are so easy to break if your not careful
Draw tape/snake although they can be rip-off priced......they always get pilfered, I end up buying 6 at a time, which last about 2 days before all gone....again....
I've got 2 pairs of long handled surgical forceps, one has an angled nose. Invaluable for reaching into places where there's not a lot of room and grabbing stuff.
Reply to Handy tools in the Electrical Tools and Products area at ElectriciansForums.net
I have tried pretty much every tool bag ,box, bucket ,case, caddy, tote organiser that you can imagine. and I have gone full circle and just gone...
Aye .... one can never have enough screwdrivers .... or pliers, crimping tools, stripping tools and cutters .... One of the best tools I've...
