Haphazard lighting layout. | Page 2 | on ElectriciansForums
Discuss Haphazard lighting layout. in the Talk Electrician area at ElectriciansForums.net
In my last 5 rewires, I've started running live & neutrals to each switch position into deep switch/socket boxes and looping to each switch position. With this method, you only have one twin cable at the light position.
The neutrals are connected using Wago push fit connectors which incidentally, you can use for inaccessible connections provided they're within an enclosure which has provision for anchoring the cables.
i have seen push fit connector blocks which apparently do not need to be accessible but if you have a good pair of ratchet crimps and individually amalgamate tape each joint to disallow moisture ingress and movement( having pulled each joint to test for fastness), I see nothing wrong with this, though I'm not in charge and i'm sure I'll be corrected
dinosaur thats okay but what about the carpet ? Wouldnt you need to cut that also to make it easily accessible !!!!
Got access panels under my carpets noone has ever complained or said it cant be done. Like Shakey asked a couple of months ago - what is the definition of accessable?
You can roll a carpet back you cant roll sodding chipboard sheets back!!!!!
If it's the same product then yes. It comes in a case with all the bits and think of the time saved trying to lift boards etc
Just bought some Ashley non maintenance junction boxes - they're brilliant, very quick push fit and loads of room in them. I'm not going to use anything else from now on.
Think you can get dryline junction boxes which you can fit in the ceiling and then screw the rose/fitting to it. That way the wires are accessible but not actually in the light fitting.
Reply to Haphazard lighting layout. in the Talk Electrician area at ElectriciansForums.net
Another tip for metal boxes, the single box version…. Is to fold flat the fixing lugs that you won’t be using… the top and bottom ones
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
