Has anyone seen 3 phase lighting | Page 3 | on ElectriciansForums
Discuss Has anyone seen 3 phase lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As far as I am aware, there are no 3 phase light fittings.
I disagree, a while back we were researching flood lights for a particular job and a colleague discovered some 3 phase flood lights.
Not those particular ones but I found this online this morning (Spec'n below).
[ElectriciansForums.net] Has anyone seen 3 phase lighting
See for the lights to work with a 3 phase breaker and one neutral could you have 3 switches or just one switch to a contactor ? My thinking 3 separate switches potentially the neutral carrying a return voltage if you work on other lights
So, use 3 SP breakers from 3 Phases instead of a TP.
3 DP switches with individual outgoing neutrals to 3 light circuits.
Reply to Has anyone seen 3 phase lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
