Has fuse box been left safe | on ElectriciansForums
Discuss Has fuse box been left safe in the DIY Electrical Advice area at ElectriciansForums.net
ailsac
Uk
Apparently half the downstairs works were on the left of the fuse box and half on the right sparky replace one of the fuses ( allegedly as I wasn’t in ) and decided not to use any of the left switches. everything is now powered from the right switches but he didn’t bother to relabel what’s what , so if in the future anything trips out I won’t be able to identify what’s what to eliminate? Is this corrrct or safe ? I’ve no idea where the shower or upstairs light or downstairs sockets are wired ? There were not 3 spare on the right ?[ElectriciansForums.net] Has fuse box been left safe
TL;DR
Sparky decided not to use any of right rides used only right switched. Now I can’t see what’s what. Is this legal or safe
Apparently half the downstairs works were on the left of the fuse box and half on the right sparky replace one of the fuses ( allegedly as I wasn’t in ) and decided not to use any of the left switches. everything is now powered from the right switches but he didn’t bother to relabel what’s what , so if in the future anything trips out I won’t be able to identify what’s what to eliminate? Is this corrrct or safe ? I’ve no idea where the shower or upstairs light or downstairs sockets are wired ? There were not 3 spare on the right ?View attachment 119207
It's an older MCG consumer unit and these are hard to get parts for.
These dual RCD units are problematic as one fault plunges half the home off
I would suggest a new RCBO consumer unit. This means a fault will trip only one device
I would also suggest Hager as the spare parts are easier to get
Reply to Has fuse box been left safe in the DIY Electrical Advice area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
