Has wire marking changed - or what do you use. | Page 2 | on ElectriciansForums
Discuss Has wire marking changed - or what do you use. in the UK Electrical Forum area at ElectriciansForums.net
SteveG
West Yorkshire
When I was an apprentice sparky back in the 1970's and we were rewiring houses or first fixing new houses/flats, I was taught a marking method for T&E that seemed to be common but undocumented throughout the industry.
I'm talking specifically about lighting circuits and the loop-in system.
At the ceiling rose there would be (normally) 3 twin cables. The L&N in and out would have a notch or bite taken out on the sheathing on the red side (brown now I know) and the switch wire would have a single line across it done by pliers. If there was a second light on the same switch this would have an X on it done by pliers.
At the switch; if it was a 2 way there would be 1 twin from the light and a 3 core+e (red/yellow/blue) between the 2 way switches.
The connections at the 2 way confused me at the time as to how they worked (but they did) I only worked it out much later.
The yellow would go in the common terminal and the 2 reds in SW1 and the blue and black in SW2 (and yellow in the common at the other switch.
Not done any house wiring in 35 years. Is it still done like this?
Belt and braces really. But if you bare all three off and forget which is which you have the indents on the wires to give you a clue. :)
Same here , for the odd time the
Same here really , for the odd time they have been damaged or disappeared owing to other trades.
Habit really , it only takes a minute .
I basicly used the same as the op apart from the l/n. I just never marked these at all. So the common 3 plate would have 2 unmarked cables and one with a line for the switch drop. A cross for another light.
Why do you need to know live in live out when second fixing?
sometimes you need to 2nd fix when some of the fittings are not on site, so knowing which is feed in and feed out can be useful if you need to get part of the lighting up and running.
Ive always just marked the switch wire with a nick. Dont see the need to mark the feeds up, and as for the sharpie, its a complete waste of time. After the pill head painters slapped a full bucket of matt white on yer cables yer F****D.
Everyone I've met who uses a system of notches swears blind that their system is the industry standard.
It is not.
It may have been what they were taught but it wasn't what anyone else was taught.
There is no system of notches made reference to in any official documentation and it isn't taught in colleges, it's down to personal preference and only works if everyone working on the job knows the system.
I'm one of the ones who writes on the sheath what it does - if you've got cables with 'feed', 'S/L', 'strappers' etc on them then it's clear to anyone what the cables are for. Sure the decorators could paint over them, or the wood butchers could drill into them, or the spreads could butter over the boxes, but you could go on forever like that.
What about the plasterers that like to fold your wires (if you don't) right into the sockets and than completely skim over them leaving you to try find them or even forget one. :)
Bit like this;
[ElectriciansForums.net] Has wire marking changed - or what do you use. [ElectriciansForums.net] Has wire marking changed - or what do you use.
In was plastered over circa 1966, and I discovered it still live in 2015!
Bit like this;
View attachment 33425 View attachment 33426
Fantastic !
I had one at mine that I only found because the back box rusted and blew out the plaster. House was built early 70s and I reckon it never saw action. Then I had the rising damp to fix as well :)
I would leave the loop blank and mark sw with one line/mark across the cable, sw 2 with 2 lines and so on.. Intermediates marked with a cross and strappers 2 lines along the cable.
That was all in the olden days before I started with knx, now it's a doddle :sunglasses:
Reply to Has wire marking changed - or what do you use. in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Yes still see the odd red white and blue out in the wild, usually without cpc, iirc that colour code was only used for a short time...could be...
