Guest viewing limit reached
I am sure when I qualified for the 16 edition we spoke about how to treat a ring main.
I know the majority of the time we just learned how to read the book and how to find needed headings but I am sure we also spoke about ring mains.
If a socket has two cables coming into the back box then it is part of a ring main. If it has three then it is part of a ring main with a spur and if it only has one then it is a spur.
I spur cannot be added to an existing spur because it would then incorrectly be taken as a socket on the ring main with two cables coming in to it.
A few of the threads ...........It says this is too long and won't let me write any more?
It could be a radial
It could still be a radial
Or a radial
The reason is that a spur off a spur, depending on what's off it, cable size etc could overload the cable.
Ring finals are old hat.
There’s the difference.
Back in the 16th, it was still referred to as a ring main.
Now it’s a ring final.
I did the 16th and it was a Ring Final back then but nearly everyone called it a Ring Main , heck most people still call it a Ring Main
It really is about time the RFC / Ring Main was ditched as they simply aren't needed in this day and age
How he viewed or does view ?
Difficult to be certain as the forum seems to have limited the length of his post. Hopefully the OP will be able to return and clarify.
I get where you're coming from as all that can be ascertained from a socket with two cables coming in is that it's not the end point of a radial. With one cable, it could be a spur or it could be the end point of a radial. With three cables it could be lot of things, but I took the OP to mean a known ring final circuit and one that hasn't been butchered to within an inch of its existence.
I found a single socket with 5 cables at it the other day , wonder what the OP would make of that
Yes I still call it a ring main, is that what is now called a ring final? What is a radial?
I must admit ring main as the main ring of wires in a room makes more sense to me than ring final.
I understand the reason for a ring is so that if one wire fails along the ring somewhere, especially the earth, there is still a good chance the earth will still be good around the other side of the ring.
Does final refer to the end of the set of wires or is it still made in a loop that goes back to the main fuse board at both ends?
Basically is a ring final just another name for a ring main or not? What is a radial?
Can you now have spurs off spurs 'cos that sounds like anarchy or "butchered to within an inch of its existence." as one reply states and to me difficult to test and work on as I am discovering from the club house I am trying to 'tidy up'.
Yes, a Ring final is the same as a ring main.
What is a radial?
A radial is a single cable with no loop back to the CU.
You are correct, but you wouldn't know if there was a break in any part of that ring, and in certain circumstances could be dangerous.
You're allowed one spur per socket outlet.
But if you Spured off to a FCU then you can add after the FCU.
Ring finals/Mains are a lot more difficult to test and fault find on.
You’re trained to 16th Ed, and you don’t know what a radial is?
Any circuit that ends at its point of use, such as a socket, lighting etc is called a final. Rather than a distribution circuit like from a main distribution board to another, like from a house to an outside garage.
The terminology in the big book just uses it with “ring final”, but doesn’t say things like “lighting final” or not very often mentions it.
A lighting circuit can be described as a radial, where there is one cable coming from board and everything branches off… but it’s used mostly for power circuits.
An immersion or storage heater point is a radial with only one point on it, but you could have any number, as long as the circuit is designed correctly.
It's a spidered radial ring final spur :)
Even more impessive was the fact 2 cables were old rubber so presumably the old original house ring , there was one white red black 2.5 which was a spur off the ring and then 2 newly installed grey brown and blue cables which were infact a mini ring all connected to the back of the single socket.
I wish I hadn't dropped the socket off as getting them all back in the box was a nightmare
home
Other
If other, please explain
retired
Business Name
none
Have the rules for ring mains changed over the years?
Electrical Engineering Chat
Bob Bob,
Mike Johnson,
