have you got | Page 2 | on ElectriciansForums
Discuss have you got in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
a customer rings up can you fit a light up ,yes not a problem ,any way goes to the house its in their ,front room can you put that up looking at the box ,mmmm, out of the box and found this .dont mind putting lights up but this weight a ton , me was thinking of only fools and horses .where Roddie when you want him.
[ElectriciansForums.net] have you got
A spark of humour there Dave. :)
Loose connection probably
[automerge]1576790571[/automerge]
Got called to a job once...same thing buzz, can pop a light up for us.....
Turned up and it was a full on antique chandelier at the top of a 3 story open staircase!!.....I genuinely thought it was a wind up but the lady was serious, we had to reinforce the loft joists and fit a ratchet hoist system in the loft with steel cable in the end....can you pop a light up she said ?
So it was a wind up in the end then.
Buzz would you know where that was purchased from as the other half likes the look of it:rolleyes:.
When I re-wired my house I put off cuts of 18mm chipboard flooring supported by noggins in above all the lighting points with 20mm holes drilled through so the weights no issue.
Did something similar above the stair well in my place. Downlights plus a separate central feed in case of some fancy chandelier. At present I just have a redundant piece of T&E sticking out of the ceiling. Might tie a bit of tinsel to it :)
Reply to have you got in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
