Having the time of my life | on ElectriciansForums
Discuss Having the time of my life in the UK Electrical Forum area at ElectriciansForums.net
1stfix2ndfix
Trying to get the internet back in a room
in the front room is a telephone point inside is a cable with an orange green white and black single at this point the orange goes into one hole and the white another (there's no numbers) and the green and black have been chopped of. This cable come out of here and onto a grey box (outside) where it meets another 2 cables ones black with 6 singles and the others the same as the one in the front room so 4. Well the cable from the front room orange and white contect to the black cables orange and white. The cable to my room connects to the black and green of the black cable which means at my end I've got a cable with 4 singles, orange white green and black and a telephone socket with 6 terminal points. 2 lines of 3 down 1,2 3 on the left and up 4,5,6 on the right. I'm trying all sorts but nothing seems to be working
[ElectriciansForums.net] Having the time of my life
your incoming pair will have 48 -50V DC on it. find that first. then this pair needs to be connected by whatever means to terminals 2 and 5 of your phone socket/s. not absolutely sure, but i think + goes to 5. ( it will work either polarity, but the correct polarity may be better)
There is a bank of 6 terminals 3 on the left 3 on the right.....the centre left and the centre right terminals are all that is connected......so start at the master socket and match these terminals up in all sockets..master marked 2 & 5
Is the answer pork?
Im of today and my multimeter is in the van with my tools ill be able to grab it tomorrow but it a ethos one and having tried it on the cables before it didnt say anything. It is **** though with ott guards on it. Bear with me and ill report back tommorow evening on this one tel mate
in the front room is a telephone point inside is a cable with an orange green white and black single at this point the orange goes into one hole and the white another (there's no numbers) and the green and black have been chopped off. This cable come out of here and onto a grey box (outside) where it meets another 2 cables ones black with 6 singles and the others the same as the one in the front room so 4. Well the cable from the front room orange and white contect to the black cables orange and white. The cable to my room connects to the black and green of the black cable which means at my end I've got a cable with 4 singles, orange white green and black and a telephone socket with 6 terminal points. 2 lines of 3 down 1,2 3 on the left and up 4,5,6 on the right. I'm trying all sorts but nothing seems to be working
If I can get my head around all that above (!!! :) )...
It seems you've got a completly disconnected cable in your room.
I'm most probably wrong though! :smilielol5:
Reply to Having the time of my life in the UK Electrical Forum area at ElectriciansForums.net
This UK company seem to sell parts for them so it might be worth contacting them after that you could try the manufacturers La Rocca | Máquinas de...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
