sxsparky
is it a combi boiler? if so the boiler will control the heat of water it outputs
how much do you charge to wire heating
i charge £150ish dependant on job, how rich customer is, where and whats to be done.
Y on every ground source heating system does it need 2 supplied and trips a 30ma RCD there commtioners state 100ma as it always happens with these systems with 10mm and 1.5mm feeds
gravity fed chr!s and cant swap wires cause lcd display on timer
Have you put a fancy programmer on, the problem with the L plan is when the heating port valve is energised it will heat both circuits, you only get hot water temp control when the programmers is in hot water only mode.
To switch to a C plan which offers greater control an allows full programming, you need a port valve with auxiliary(white cable) and place the valve in the hot water circuit.
Going back tonight i'm going to put the old programmer on and see what happens...
Sound like you have wired it correctly, just that the new programmer does not allow Hot Water Only, there are alternative methods, but all require extra port valves or different valves and controls etc.
didnt realise there were so many variations of plans, the whole thing works though thats the worry - albeit in reverse! when I call for heat on the room stat the boiler fires and heats the cylinder, when I boost for hot water the boiler fires and the rads heat up, only thing they each heat wrong side of plumbing circuits.
Has anyone seen these kits, hope plumbers dont start using them it will put us out of work, plug and play things really simple View attachment 8865
