Head torch | Page 2 | on ElectriciansForums
Discuss Head torch in the Electrical Tools and Products area at ElectriciansForums.net
the duracell one with the batteries on the back is excellent too, I find I break the sf cheapos too easily! Think it's around 20 sheets or so .
All I would add is this, make sure you buy one that has the facility to tilt the light fitting. You don't want one that just points straight ahead at all times, as you will find this a real pain if you are doing any close up work i.e. if you are working one something about 8 to 10 inches in front of you.
Reply to Head torch in the Electrical Tools and Products area at ElectriciansForums.net
I agree no benefit in having it at the Db.
K
How much adhesive needs removing between tiles & covering a chip Hi, Looking for advice mainly on how much adhesive I should remove from between...
kitkat
K
