Heat resistant flex 3183TQ vs 3093Y | on ElectriciansForums
Discuss Heat resistant flex 3183TQ vs 3093Y in the Australia area at ElectriciansForums.net
ringer
Peterborough
What is the difference between these two specs for heat resistant flex? Have to fit some in a chip shop and not sure which to go for.
3093Y PVC/PVC in accordance with BS7655
Flame retardant to BS4066 Part 1
Voltage Rating 300/500volts
Temp Rating 90°C maximum conductor operating temperature
Outer Sheath Colour - White
Core Colours - Blue,BrownFlexible cables suitable for hot environments where temperatures do not exceed 85°C. Resistant to oil and grease. Applications include night storage heaters and immersion heaters etc.
3183TQ
Construction: Tinned annealed copper conductor, EPR insulated cores twisted together and CSP sheathed.
Standards: BASEC certified to BS6500.
Conductor: Class 5 flexible tinned copper conductors to BS EN 60228:2005 (previously BS6360)
Standard Colours: Cores - Brown, Blue, Green/Yellow / Sheath - White
Voltage Rating: 300/500 Volts
Temperature Rating: -20°C to +85°C.
All i can see is ones flame retardant and resistant to oil and grease sounds like the one to use
Thanks for that Nick. Unfortunately I am non the wiser because I am unable to discern the difference (apart from 85 degs vs 90 degs) and I am not conversant with the british standards quoted.The application is in a chip shop, and the heat it has to resist comes from outside the cable, not necessarily due to large currents flowing through the cables. 3093Y seems to be significantly cheaper which makes me rather doubtful as to its suitability. Any suggestions as to which one I should select?
To be honest, am not sure yet - am just going on say so of shop owner. Planning on going round soon (may get free bag of chips!) to check it out. Just wanted to be genned up on technical specs so I can best assess what is needed.
Looks like 3183TQ would be best - rubber/butyl outer and resistant to oil & grease (which will likely be there is spades in this environment)
Am guessing 3093Y is more appropriate for lighting applications and have seen a description 'unsuitable for industrial environments'.
the reason i asked is if they are going to be permanantly fixed why not use FP200 or a mains rated flame retardent cable ,but out of the youve quoted id use the 3183TQ as its resistant to oil and grease as well as 85 degree and chip shops are full of grease
[ElectriciansForums.net] Heat resistant flex 3183TQ vs 3093Y[ElectriciansForums.net] Heat resistant flex 3183TQ vs 3093Y yes i had that problem grrrr so id just go for the 85 deg cable then job done
Nick, are you saying that heat-protection covering (butyl) gives rodent protection? Thought I might need swa. Not sure how to protect the 10mm earth though.
Just had a thought, I may be able to route them out of harms way. If so then no special protection reqd. Will have to work out how to support cables as they are within a (hot) metal enclosure. Drilling is out ,so is adhesives. Guess I could spot weld them :cool:
ITs a food service area they should not have rodents , well the little squirrel attack i had , i had to replace all the wiring and the whole lot was re done with SWA and also installed two ultra sonic rodent reppelants
Reply to Heat resistant flex 3183TQ vs 3093Y in the Australia area at ElectriciansForums.net
Also Merry Christmas and Happy New Year from Electricians Forums. :) I think 2025 should see some house building going on which will free up...
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
