Heater temperature stopping | Page 2 | on ElectriciansForums
Discuss Heater temperature stopping in the UK Electrical Forum area at ElectriciansForums.net
J
jimjim2991
Using to a heater to heat 5L of water.
1. How can I stop this heater at 70C without a thermostat?
2. Will a potentiometer work?
Whatever you do, don't just wire a potentiometer in series with your element!!
As said above, you need a sensor/thermostat of some sort. Why do you specifically not want to use a thermostat? This is the sort of job they are designed for!
What would happen if I wired in a potentiometer ?
The temperature control options I have seen have been quite expensive!
Can you please explain how you are going to wire the potentiometer into the circuit. You have been informed that this will not work.
What do you class as 'expensive'?
A potentiometer is not designed to handle the current of a heating element. They will only handle a few hundred milli watts as a rule. There are high power versions available but these are rather specialist and probably more expensive than a simple thermostat.
If you wire a potentiometer in series with your heating element it will glow brightly and emit smoke.
Okay, no potentiometer.
What kind of thermostat might I need? How do I control the temperature of water? How would these items send information to the heater?
Reply to Heater temperature stopping in the UK Electrical Forum area at ElectriciansForums.net
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
Thank you for the suggestion!
