Heaters - kw how much? | on ElectriciansForums
Discuss Heaters - kw how much? in the Australia area at ElectriciansForums.net
lurch
i need to put a panel heater in a flat. has any body got a method of working out how much kw per cubic metere is required to heat the flat sufficiently?
Rgds
dimplex are good. avoid cheap and nasty! explain to customer about this. i have had customers supply cheapo and they call me back in twelve months to 'investigate' it not working haha. plus, dimplex always have stat etc so allow that bit extra cash and fit dimplex. the customer is sure to be happy and recommendations follow :)
wants its own dedicated circiut ideally to and 13a fuse spur or isolator to protect flex of heater
Reply to Heaters - kw how much? in the Australia area at ElectriciansForums.net
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
From the front cover of the manual: Newlec Helpline: 0800 783 6909 https://www.manualslib.com/manual/3408290/Newlec-Nlsh050.html#manual I think...
