P
Philip Thrower
Go Wales Go. seriously, I have a separate ring main 2.5 cable on a 32 mcb. It has 7 1kw heaters connected. Does this sound okay. The electrician has signed it off ?
Discuss heaters in the UK Electrical Forum area at ElectriciansForums.net
Regulations recommend not too
Do they? Which regulation would that be then?
Appendix 16 note ii " not supplying immersion heaters, comprehensive electric space heating ​or similar"
Granted it is not a regulation, but it is guidance on the use of reg 433.1That is not a regulation, and it is also concerned with a ring final serving socket outlets. The OP is talking about a ring which has been designed and installed specifically to serve heating points.
It is concerned with RFCs using socket outlets and FCUs which I assume is being used here
But surely the heaters will be connected via BS1363 FCUs making it a RFC as per 433.1.204I read the OP as if the circuit is exclusively for the 1Kw panel heaters, so it doesn't apply IMHO
I think I would of preferred two 20A radial circuits
Reply to heaters in the UK Electrical Forum area at ElectriciansForums.net
