P
Philip Thrower
Go Wales Go. seriously, I have a separate ring main 2.5 cable on a 32 mcb. It has 7 1kw heaters connected. Does this sound okay. The electrician has signed it off ?
Discuss heaters in the UK Electrical Forum area at ElectriciansForums.net
Just take a step back from your blinkered approach to the regulations for a minute and try a bit of independent thinking. Yes you could argue all day long that it could be treated as if it was the standard circuit featured in the appendix. But it doesn't have to be an adaption of. A standard circuit, it is a circuit which has been designed for this specific installation. There is nothing to say that you may only use the standard circuit arrangements in 7671, they are just there for convenience in basic installations.
Anyone with some sense and a bit of knowledge can design perfectly compliant circuits without using the standard circuits.
It's no different to the infamous lollipop circuit,
Not being blinkered but giving my point of view which happens to agree with these particular regulations. The circuit may well of been designed for the heaters but he has ended up with a standard RFC which it is recommended not used in this method
He has not ended up with a standard ring circuit, as a standard ring circuit feeds socket outlets. This is more akin to the appliance ring circuit which appears occasionally as a ring dedicated entirely to feeding kitchen appliances.
A dedicated space heating circuit with ample current for everything connected to it?Go Wales Go. seriously, I have a separate ring main 2.5 cable on a 32 mcb. It has 7 1kw heaters connected. Does this sound okay. The electrician has signed it off ?
Reply to heaters in the UK Electrical Forum area at ElectriciansForums.net
