Heating system with only one two port valve. Is this dangerous ... | on ElectriciansForums
Discuss Heating system with only one two port valve. Is this dangerous ... in the UK Electrical Forum area at ElectriciansForums.net
E
egginyourface
Came across a heating system which had only 1x 2 port valve which was used only for the heating. There was another valve which had been disconnected from the mains but set in open position. I assume this was for the hot water.
Then From the junction box there's one three core going up to 2 x cylinders in the loft. Am i correct in thinking this is dangerous?
Shouldnt there be a valve to control hot water to cylinders
In the past it was common to have no valves.
The Hot water temp relied on the boiler setting and the heating was controlled by pump on or off.
However if it's an unvented, which Megaflows are, it MUST have a normally closed 2 port valve on the boiler flow to the cylinder controlled by a safety over-temp stat on the cylinder.
It needs someone with G.3 to sort it out.
Plumbers aren't the only one's with G.3
Your right. It's a in unvented cylinder. Had a look at it today. I'm not involved with the system myself but out of curiosity opened the junction box and noticed the hot water 2 port valve has been disconnected. Theres a 3 core whicj leaves the jb and goes upto cylinder in the loft. I asked the plumber why he hasn't re instated it and he said it works fine with out it.
Now I'm interested in learning how these systems work and have feeling this is unsafe.
I personally (as a spark!) think it is unsafe and contravenes G3.
The 2 port valve is often supplied by the manufacturer of the cylinder, they wouldn't hand you a £50 zone valve for nowt ;-)
Reply to Heating system with only one two port valve. Is this dangerous ... in the UK Electrical Forum area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
T
Indirect (Boiler Fed) Megaflo Doesn't Stop Heating Hi, I noticed yesterday that when my HW is on, that the boiler runs constantly... I even...
techweb
T
