Heating System | Page 2 | on ElectriciansForums
Discuss Heating System in the Australia area at ElectriciansForums.net
steve4545456
Hi there, I,ve just joined this site in the hope I can get some help with a job that I,m doing. Its a standard fully pumped heating system, three zones (one for hot water, one downstairs heating and one upstairs heating) All controlled by a three channel timeclock. The hot water is controlled by a tank stat, the downstairs heating is controlled by a room stat and the upstairs heating works off the clock alone. There is a two port valve for each zone. My problem is that the plumber has installed an additional pump, due to the size of the house. So no matter whether the hot water or the central heating calls for heat, both pumps are running. He reckons with the way he has it plumbed, the other pump will be pumping against nothing and could eventually burn itself out ,if its constantly running. So I need a way of one pump knocking off whilst the other is running and vice versa. Obviously if it were only the one pump it would be happy days but this is new to me and any advice would be much appreciated. cheers.
steve.
The second pump may be a bronze pump whiuch is used to help push the hot water around,a set up used in large hotels ect.Just needs connecting with the call of the cylinder stat then it would only run if there is a demand for hot water.
Reply to Heating System in the Australia area at ElectriciansForums.net
Thanks I understand it now just getting to grips now with the different types and different ways of wiring them
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
